Old 11-03-2009, 07:18 PM   #51
larboc@hotmail.com
My tractor's sexy.
larboc@hotmail.com's Avatar
Member # 70148
Originally Posted by 64dumptruck View Post
since i am going to install a kegarator and a grill i was thinking propane, but i will probable go with multi port fuel injection, and 87 octane pump gas.
Might just add some methonol to the mix
Did you notice cheif yelling alot's is propane?
Thread deleted by norcal250
Reason: MOST EVERYONE ON THIS F*CKING PIECE OF SH*T FORUM ARE A**HOLES
Scoutzall Build (a.k.a. Project CornDog)
BAN Spawn_X!
larboc@hotmail.com is offline   Reply With Quote
Old 11-03-2009, 09:06 PM   #52
JetFxr
JetFxr's Avatar
Member # 4586
Why can't numbs get this, awesome first post. Bring on the tech even if it has nothing to do with wheeling it is tech
I'll have mine on the rocks
JetFxr is offline   Reply With Quote
Old 11-04-2009, 12:05 PM   #53
64dumptruck
Blower Binder
64dumptruck's Avatar
Member # 142191
Sorry i cannot post any pics today, I forgot to charge the battery's in the camera because i am a dumbass! This weekend i mocked up the carb spacer to the rpt intake and started getting ready to mount the the plate to the intake, I havent done any cutting yet, but it is looking good! the blower is about the same length as the block, and the drive i have looks like it will fit great, i was then sidetracked by a wood fired boiler me and a buddy are building.
I also had a chance to look at the bottom end of the 266 that i recived for free, it looks tighter than the engine that i have in the truck. I think this will be the engine i will build to get the full potential out of the supercharger.
oh by the way the max boost for a 266 using the dynamic compression ratio formula is 8lbs with premium or about 6lbs for 87 octane i am a low lander a 961 ft altitude
Edit: I will try to post pics before Friday!
64dumptruck is offline   Reply With Quote
Old 11-04-2009, 12:17 PM   #54
Ben Segrest
Semi-Broken
Ben Segrest's Avatar
Member # 13467
pffft, I'm at ~36 feet and my parents house is at about 16'. Really cool thread, though. We're all sitting here hoping you don't run out of steam before you finish.
Originally Posted by Willyswanter's Dad View Post
I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling
Ben Segrest is offline   Reply With Quote
Old 11-04-2009, 02:57 PM   #55
Mechanos
Pirate4x4 Addict!
Mechanos's Avatar
Member # 6704
Originally Posted by Ben Segrest View Post
...We're all sitting here hoping you don't run out of steam before you finish.
Duh.... he said he's building a wood fired boiler.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 11-04-2009, 03:50 PM   #56
larboc@hotmail.com
My tractor's sexy.
Member # 70148
pics of the boiler?
BAN Spawn_X!
Old 11-04-2009, 04:06 PM   #57
64dumptruck
Blower Binder
Member # 142191
pics of the supercharger build.
unless you guys want both??
Old 11-04-2009, 04:59 PM   #58
Binder
Binder's Avatar
Member # 1684
Rather have pictures of hot chicks with great big fake milk jugs........But that's just me.
S.N.O.R.T.
Binder is offline   Reply With Quote
Old 11-04-2009, 06:30 PM   #59
ChiScouter
City Slicker
Member # 9835
If you want to talk about your boiler it might be more appropiate to start up a new thread in chit chat.
79 SSII Fiberglass bod, hydroboost, 4whl discs. looks like im going to be a bowtie guy, ls1, 4l60, klune on the way
ChiScouter is offline   Reply With Quote
Old 11-04-2009, 08:41 PM   #60
64dumptruck
Blower Binder
Member # 142191
here is the manifold with the spacer and the plate
This is the drive gear of the 8v92 that i re-drilled and tapped for the drive pattern
This is the front cover
the front cover assembled
Oh and just for you binder EPIC BOOBS
Old 11-04-2009, 10:53 PM   #61
CSmith
CSmith's Avatar
Member # 31658
You are going to need to add some supports to avoid broken parts. Of course I'm talking about your intake manifold and those sweater kittens.
'77 Scout Terra, Extended Cab, SOA, 4bt Cummins, ZF 5 speed, NP205
CSmith is offline   Reply With Quote
Old 11-05-2009, 06:08 PM   #62
Blind Driver
Blind Driver's Avatar
Member # 29177
I see stripped bolts and bent aluminum in your future
Originally Posted by Roxywheels View Post
If Chuckie is pm'ing, that means he signed up under another name and even if Camo might possibly have reconsidered his decision, he won't now because he totally fucked himself. You may want to pass that on to him.
I don't give him coming back any thought at all.
Blind Driver is offline   Reply With Quote
Old 11-05-2009, 07:13 PM   #63
Buck Dodson
Buck Dodson's Avatar
Member # 35185
So where do you see the weak link and what do you recommend for improvement?
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
Buck Dodson is offline   Reply With Quote
Old 11-06-2009, 09:43 PM   #64
ChiScouter
City Slicker
Member # 9835
to the OP I am on the SW side of the city, if your looking for parts give me a heads up. I don't see much IH stuff at the boneyards these days, but I hear there is a yard off of I57 near kankakee with a number of binders
Old 11-07-2009, 06:42 AM   #65
Blind Driver
Member # 29177
Too much overhang on the blowing mount that goes to the spacer. That blower is going to produce a bunch of tension trying to pull the nose down when the belt is tightened. I predict the aluminum spacer will bend. Or maybe the rear bolts will pull out of the spacer/manifold.
Old 11-07-2009, 07:57 AM   #66
chris fresh
I LOVE HATERS
Member # 69678
awsome build! as far as the overhang issue, could you build some sort of bridge from the two front intake mounting bolts? up and over the water neck.sort of a truss system to make it more ridig,and any downward force would go to the block.
78 SII very healthy 327,th-350,np205,35''boggers
71 800B LT-1,400,203/205,FF14,d-60,42'' rockers on beadlocks
To my great friend rob,RIP buddy we'll never forget you.
chris fresh is online now   Reply With Quote
Old 11-07-2009, 08:56 AM   #67
dboy
Member # 52376
Thats what i was thinking, some sort of braces from the bottom on the blower studs to the intake mounting studs.
dboy is offline   Reply With Quote
Old 11-07-2009, 09:49 AM   #68
Blind Driver
Member # 29177
But, but, but then it wouldn't look like a Weiand air-gap manifold anymore
Old 11-08-2009, 12:45 AM   #69
larboc@hotmail.com
My tractor's sexy.
Member # 70148
Should have built it all out of cast iron or steel like IH would have.
BAN Spawn_X!
Old 11-17-2009, 09:01 AM   #70
64dumptruck
Blower Binder
Member # 142191
front hub and blower pulley bored and re-drilled for the hub
Hub+pulley assembled and idler pulley
Originally Posted by JetFxr View Post
Even the BP will not condone fucking up a Scout with Toyota parts. GO AWAY, the idea of using metric tools on Scout is as wrong as two men fucking.
Old 11-17-2009, 09:57 AM   #71
JF
I'm old Greg
Member # 133890
faster, faster faster ..... when's it gonna run?
pre-christmas?
JF is offline   Reply With Quote
Old 11-17-2009, 12:07 PM   #72
64dumptruck
Blower Binder
Member # 142191
Most likely around feb
Red star added
